  • You must enable EAP globally.
The RADIUS server uses the secret key to validate users.
    enable
    configure terminal
  2. Configure a secret key:
    radius server host WORD<0–113> used-by eapol key WORD<0-32>
  3. Optional: Configure accounting parameters for the RADIUS server:
    1. Configure the UDP port:
      radius server host WORD<0–113> used-by eapol acct-port <1-65536>
    2. Enable accounting:
      radius server host WORD<0–113> used-by eapol acct-enable
  4. Optional: Configure secure options for the RADIUS server:
    1. Enable RADIUS Security (RADSec):
      radius server host WORD<0–113> used-by eapol secure-enable
    2. Select the protocol for secure mode:
      radius server host WORD<0–113> used-by eapol secure-mode <dtls | tls>
    3. Specify a secure profile for the server:
      radius server host WORD<0–113> used-by eapol secure-profile WORD<1-16>
    4. Configure the log level:
      radius server host WORD<0–113> used-by eapol secure-log-level <critical | debug | error | info | warning>
  5. Optional: Configure other optional parameters for the RADIUS server:
      radius server host WORD<0–113> used-by eapol port <1-65536>
    2. Configure the server priority:
      radius server host WORD<0–113> used-by eapol priority <1-10>
    3. Configure the maximum number of retries:
      radius server host WORD<0–113> used-by eapol retry <0-6>
    4. Configure the server timeout:
      radius server host WORD<0–113> used-by eapol timeout <1-180>
  6. Enable the server:
    radius server host WORD<0–113> used-by eapol enable
Add an EAP RADIUS server:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#radius server host fe80:0:0:0:21b:4fff:fe5e:73fd key radiustest used-by eapol enable
The following table defines parameters for the radius server host command.
Variable
Value
acct-enable
Enables accounting for the server.
acct-port <1-65536>
Specifies the accounting port. The default is 1813.
enable
Enables the RADIUS server host.
host WORD<0–113>
Configures a host server. WORD<0–113> specifies the IPv4 address, IPv6 address, or fully qualified domain name (FQDN). If you use an FQDN, you must also configure the switch to use DNS.
key WORD<0-32>
Specifies the secret key.
port <1-65535>
Specifies the port ID number. The default is 1812.
priority <1-10>
Specifies the priority. The lowest number is the highest priority. The default is 10.
retry <0-6>
Specifies the retry count. The default is 1.
secure-enable
Enables secure mode on the server. The default is disabled.
Specifies the RADIUS secure server log severity level. The default is error.
Specifies the protocol for establishing the secure connection with the server. The possible values are:
  • dtls - Datagram Transport Layer Security (DTLS) encryption over User Datagram Protocol (UDP)
  • tls - Transport Layer Security (TLS) encryption over Transmission Control Protocol (TCP)
The default is TLS.
Important:
To avoid TLS handshake issues if the switch and RADsec proxy server run different versions of OpenSSL, manually force TLS version 2 negotiation through the RADsec proxy by adding the following text to the radsecproxy.conf configuration file:
tls default{
     TlsVersion TLS1_2
Specifies the secure profile name.
timeout <1-180>
Specifies the timeout of the server. The default is 8.
