Use this procedure to configure the Fabric Attach assignment time-out.
    enable
    configure terminal
  2. Configure the FA assignment time-out in seconds:
    fa assignment-timeout <45–480>
    The assignment time-out must be less than or equal to the discovery time-out.
  3. Optional: Configure the default FA assignment time-out value:
    default fa assignment-timeout
Configure the FA assignment time-out:
Switch:1>en
Switch:1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#fa assignment-timeout 50
Verify the configuration:
Switch:1(config)#show fa
                          Fabric Attach Configuration
                            FA Service : enabled
                       FA Element Type : server
                 FA Assignment Timeout : 50
                  FA Discovery Timeout : 240
                     FA Provision Mode : spbm
Variable definitions
The following table defines parameters for the fa assignment-timeout command.
Variable
Value
<45–480>
Specifies the Fabric Attach assignment time-out in seconds.
The default value is 240 seconds.
