Use this procedure to configure the Fabric Attach discovery time-out.
Configure the FA discovery time-out.
Switch:1>en Switch:1#conf t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#fa discovery-timeout 50
Verify the configuration.
Switch:1(config)#show fa ======================================================================= Fabric Attach Configuration ======================================================================= FA Service : enabled FA Element Type : server FA Assignment Timeout : 45 FA Discovery Timeout : 50 FA Provision Mode : spbm
Variable definitions
The following table defines parameters for the fa discovery-timeout command.
Variable |
Value |
<45–480> |
Specifies the Fabric Attach discovery time-out in seconds. The default value is 240 seconds. |
