Use CLI for Troubleshooting
You can use CLI to provide diagnostic information.
    enable
    configure terminal
  2. Disable scrolling of the output display:
    terminal more disable
  3. View configuration file information:
    more WORD<1–99>
  4. Capture the output for the following command after you observe a problem with the device:
    show running-config [verbose] [module {app-telemetry | boot | cfm | cli | diag | dvr | eap | endpoint-tracking | energy-saver | fa | fhs | filter | ike | ip | ipfix | ipsec | ipv6 | iqagent | isis | i-sid | lacp | license | lldp | lst | macsec | mlt | naap | nls | ntp | ovsdb | port | qos | radius | restconf | rmon | sflow | security | slpp | smtp | spbm | stg | sys | tacacs | virtualservice | vlan | web | vxlan}]
  5. Capture the output for the following command after you observe a problem with the device:
    show tech
    show tech is an alias for show fulltech. Both commands provide the same output.
  6. Capture the output for the following commands after you observe a problem with the device:
    The show interfaces gigabitEthernet statistics rmon command displays information only if you previously configured rmon stats or rmon history.
    • show interfaces gigabitEthernet statistics <dhcp-relay [vrf WORD<1–16>][vrfids WORD<0–512>] [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
    • show interfaces gigabitEthernet statistics lacp [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
    • show interfaces gigabitEthernet statistics rate—limiting [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
    • show interfaces gigabitEthernet statistics rmon [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
    • show interfaces gigabitEthernet statistics verbose [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
    • show interfaces gigabitEthernet statistics vlacp [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
  7. Capture the output for the following command after you observe a problem with the device:
    show interfaces gigabitEthernet error [collision|ospf|verbose] [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Due to the length of command output, the following examples are truncated.
Switch:1>enable
Switch:1#show running-config module cli
Preparing to Display Configuration...
# Fri Feb 25 12:34:46 2022 UTC
# box type             : <hardware dependent>
# software version     : 8.6.0.0.GA
# cli mode             : ECLI
#Card Info :
#  Slot 1 :
#       CardType          : <hardware dependent>
#       CardDescription   : <hardware dependent>
#       CardSerial#       : TB012132K-H0057
#       CardPart#         : 801104-00-02
#       CardAssemblyDate  : 20210817
#       CardHWRevision    : 02
#       CardHWConfig      :
#       AdminStatus       : up
#       OperStatus        : up
--More-- (q = quit)
Switch:1#show tech
Sys Info:
General Info :
        SysDescr     : <hardware dependent> (8.6.0.0.GA)
        SysName      : <hardware dependent>
        SysUpTime    : 1 day(s), 02:39:22
        SysContact   : http://www.extremenetworks.com/contact/
        SysLocation  :
Chassis Info:
        Chassis            : <hardware dependent>
        ModelName          : <hardware dependent>
        BrandName          : Extreme Networks.
        H/W Revision       : 02
--More-- (q = quit)
Switch:1#show interfaces gigabitethernet statistics
                             Port Stats Interface
PORT     IN                  OUT                  IN                   OUT
NUM    OCTETS               OCTETS               PACKET               PACKET
1/1    1215232              1852156              18988                25083
1/2    11866260             3650340              128847               51849
1/3    0                    0                    0                    0
1/4    0                    0                    0                    0
1/5    0                    0                    0                    0
1/6    2606433776           2605569408           40718802             40712022
1/7    2383797478           2368788480           37189478             37012320
1/8    2639779622           2624836140           41201664             40945760
1/9    0                    0                    0                    0
1/10   0                    0                    0                    0
1/11   0                    0                    0                    0
1/12   0                    6776546              0                    62572
1/13   1215232              997632               18988                15588
1/14   7459408              1396224              69625                18702
--More-- (q = quit)
Switch:1#show interfaces gigabitEthernet error
                              Port Ethernet Error
PORT  ERROR   ERROR   FRAMES  TOO     LINK    CARRIER CARRIER SQETEST IN
NUM   ALIGN   FCS     LONG    SHORT   FAILURE SENSE   ERRORS  ERRORS  DISCARD
1/1   0       0       0       0       0       0       0       0       0
1/2   0       0       0       0       0       0       0       0       0
1/3   0       0       0       0       0       0       0       0       0
1/4   0       0       0       0       0       0       0       0       0
1/5   0       0       0       0       0       0       0       0       0
1/6   0       0       0       0       0       0       0       0       0
1/7   0       0       0       0       0       0       0       0       0
1/8   0       0       0       0       0       0       0       0       0
1/9   0       0       0       0       0       0       0       0       0
1/10  0       0       0       0       0       0       0       0       0
1/11  0       0       0       0       0       0       0       0       0
1/12  0       0       0       0       0       0       0       0       0
1/13  0       0       0       0       0       0       0       0       0
1/14  0       0       0       0       0       0       0       0       0
--More-- (q = quit)
The following table defines parameters for the more command.
Variable
Value
WORD<1–99>
Specifies the file name to view. Provide the file name in one of the following formats: a.b.c.d:<file>, /intflash/<file>.
The following table defines parameters for the show running-config command.
Variable
Value
Specifies the command group for which you request configuration settings.
Note:
All configuration modules are not supported on all hardware platforms. For information about feature support, see Fabric Engine and VOSS Feature Matrix.
verbose
Specifies a complete list of all configuration information about the switch.
The following table defines parameters for the show interfaces gigabitEthernet statistics command.
Variable
Value
dhcp-relay [vrf WORD<1–16> ][vrfids WORD<0–512> {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Displays port Dynamic Host Configuration Protocol (DHCP) statistics.
lacp {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Displays Link Aggregation Control Protocol (LACP) statistics.
rate-limiting {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Displays port ingress rate-limiting statistics.
rmon {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} [history]
Displays Remote Network Monitoring (RMON) statistics.
verbose
Displays a complete list of all statistics.
vlacp [history] {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Displays port Virtual Link Aggregation Control Protocol (VLACP) statistics.
  • history—Displays the VLACP port counter profile.
  • {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
    Identifies the slot and port in one of the following formats:
    • a single slot and port (slot/port)
    • a range of slots and ports (slot/port-slot/port)
    • a series of slots and ports (slot/port,slot/port,slot/port)
    • all ports on the same slot (slot/all)
    • all ports on the switch (all)
The following table defines parameters for the show interfaces gigabitEthernet error command.
Variable
Value
collision
Displays port collision error information.
ospf
Displays ports Open Shortest Path First (OSPF) error information.
verbose
Displays all port error information.
