Use Software Record Dumps
Capture a dump of the software records from ingress traffic to help troubleshoot performance problems. Generally, a verbosity level of 1 suffices.
  1. Enter Privileged EXEC mode:
    enable
  2. Dump software record information:
    dump ar <1–12> WORD<1-1536> <0-3>
Switch:1> enable
Switch:1# dump ar 1 vlan 1
The following table defines parameters for the dump ar command.
Variable
Value
<1>
Specifies the slot number.
WORD<1-1536>
Specifies a record type in the AR table. Options include vlan, ip_subnet, mac_vlan, mac, arp, ip, ipmc, protocol, all.
<0-3>
Specifies the verbosity from 0–3. Higher numbers specify more verbosity.
