Use this procedure to configure or view LLDP global information.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics > 802_1ab.
  2. Select LLDP.
  3. Select the Globals tab.
  4. After you make the required configuration changes, select Apply to save changes.
Use the data in the following table to use the Globals tab.
Field
Description
lldpMessageTxInterval
Specifies the interval at which LLDP messages are transmitted.
The default is 30 seconds.
lldpMessageTxHoldMultiplier
Specifies the multiplier used to calculate the time-to-live (TTL) value of an LLDP message.
The default value is 4 seconds.
lldpReinitDelay
Specifies the delay in seconds between the time a port is disabled and the time it is re-initialized.
The default is 1 second.
lldpTxDelay
Specifies the delay in seconds between successive LLDP transmissions.
The value is as follows:
1 < lldpTxDelay < (0.25 x lldpMessageTxInterval)
lldpNotificationInterval
Specifies the time interval between successive LLDP notifications. It controls the transmission of notifications.
The default is 5 seconds.
Stats
RemTablesLastChangeTime
Specifies the timestamp of LLDP missed notification events on a port, for example, due to transmission loss.
RemTablesInserts
Specifies the number of times the information advertised by a MAC Service Access Point (MSAP) is inserted into the respective tables.
RemTablesDeletes
Specifies the number of times the information advertised by an MSAP is deleted from the respective tables.
RemTablesDrops
Specifies the number of times the information advertised by an MSAP was not entered into the respective tables.
RemTablesAgeouts
Specifies the number of times the information advertised by an MSAP was deleted from the respective tables.
