Use this procedure to view the LLDP port information.
To modify a value, double-click on a cell, and then select a value.
- Select LLDP.
- Select the Port tab.
- View the administrative status of the port in AdminStatus.
- View whether the port is enabled for notifications in NotificationEnable.
- View the set of TLVs whose transmission using LLDP is always allowed by network management in TLVsTxEnable.
- Optional: Modify the TLVs as
follows:
- To enable a TLV, select one or more values, and then select Ok.
- To enable all TLVs, select Select All, and then select Ok.
- To disable all TLVs, select Disable All, and select Ok.
- View the CDP administrative status in CdpAdminState.
- Select Apply to save any configuration changes.
- Select Refresh to verify the configuration.
Port Field Descriptions
Use the data in the following table to use the Port tab.
Name |
Description |
PortNum |
Specifies the port number. This is a read-only cell. |
AdminStatus |
Specifies the administrative status of the port. The options are:
The default is disabled. |
NotificationEnable |
Specifies whether the port is enabled or disabled for notifications.
The default is false. |
TLVsTxEnable |
Specifies the set of TLVs whose transmission using LLDP is always allowed by network management. The following list describes the TLV types:
The default is an empty set of TLVs. |
CdpAdminState |
Specifies the CDP administrative status of the port. Configure this field to true to enable the Industry Standard Discovery Protocol (ISDP) on a port. ISDP is CDP-compatible.
The default is false. If CDP is enabled, the interface accepts only CDP packets. Similarly, if CDP is disabled but LLDP is enabled, the interface accepts only LLDP packets. To switch a port from CDP mode to LLDP mode, the LLDP status on that port must be txAndRx. |
CapSupported(med) |
Specifies the LLDP-MED capabilities supported. The default is enabled. |
