Variable definitions
The following table defines parameters for the show isis spbm ip-multicast-route command.
Variable
Value
all
Displays all IP Multicast over Fabric Connect route information.
detail
Displays detailed IP Multicast over Fabric Connect route information.
group {A.B.C.D} source {A.B.C.D}
Displays information on the group IP address for the IP Multicast over Fabric Connect route. If you select source it will also display the source IP address.
vlan <0–4084>
Displays IP Multicast over Fabric Connect route information by VLAN.
vrf WORD<1–16>
Displays IP Multicast over Fabric Connect route information by VRF.
vsn-isid <1–16777215>
Displays IP Multicast over Fabric Connect route information by I-SID.
The following table defines parameters for the show isis spb-mcast-summary command.
Variable
Value
count
Displays the total number of SPB multicast entries.
host-name WORD<0–255>
Displays the IP Multicast over Fabric Connect summary for a given host-name.
lspid <xxxx.xxxx.xxxx.xx-xx>
Displays the IP Multicast over Fabric Connect summary for a given LSP ID.
