Use the following options to display Layer 2 VSN information to confirm proper configuration.
show isis spbm ip-multicast-route [all]
show isis spbm ip-multicast-route [detail]
show isis spbm ip-multicast-route [vlan <1-4059>]
show isis spbm ip-multicast-route [vsn-isid <1–16777215>]
show isis spbm ip-multicast-route [group {A.B.C.D}]
show isis spbm ip-multicast-route [source {A.B.C.D}]
Important
When you use the command show isis spbm ip-multicast-route without parameters, or use the detail or group optional parameters without specifying a VLAN ID or VSN I-SID, the command output displays Layer 3 context only. No Layer 2 context is displayed.
show isis spb-mcast-summary [count][host-name WORD<0–255>][lspid <xxxx.xxxx.xxxx.xx-xx>]
Switch:1#show isis spbm ip-multicast-route all
SPBM IP-MULTICAST ROUTE INFO ALL
Type VrfName Vlan Source Group VSN-ISID Data ISID BVLAN Source-BEB AREA AREA-NAME
Id
snoop GRT 501 192.0.2.1 233.252.0.1 5010 16300001 10 el2 HOME area-10.0010
snoop GRT 501 192.0.2.1 233.252.0.2 5010 16300002 20 el2 HOME area-10.0010
snoop GRT 501 192.0.2.1 233.252.0.3 5010 16300003 10 el2 HOME area-10.0010
snoop GRT 501 192.0.2.1 233.252.0.4 5010 16300004 20 el2 HOME area-10.0010
snoop GRT 501 192.0.2.1 233.252.0.5 5010 16300005 10 el2 HOME area-10.0010
snoop GRT 501 192.0.2.1 233.252.0.6 5010 16300006 20 el2 HOME area-10.0010
snoop GRT 501 192.0.2.1 233.252.0.7 5010 16300007 10 el2 HOME area-10.0010
snoop GRT 501 192.0.2.1 233.252.0.8 5010 16300008 20 el2 HOME area-10.0010
snoop GRT 501 192.0.2.1 233.252.0.9 5010 16300009 10 el2 HOME area-10.0010
snoop GRT 501 192.0.2.1 233.252.0.10 5010 16300010 20 el2 HOME area-10.0010
Total Number of SPBM IP MULTICAST ROUTE Entries: 10
Switch:1#show isis spbm ip-multicast-route vlan 100
SPBM IP-MULTICAST ROUTE INFO - VLAN ID : 100, VSN-ISID : 100
Source Group Data ISID BVLAN Source-BEB AREA AREA-NAME
100.100.0.105 225.1.2.1 16003014 4052 vn-area-20.0020 HOME area-10.0010
100.100.0.105 225.1.2.1 16153041 4051 vn-area-30.0030 REMOTE area-20.0020
100.100.0.105 225.1.2.2 16003011 4051 vn-area-20.0020 HOME area-10.0010
100.100.0.105 225.1.2.2 16153049 4051 vn-area-30.0030 REMOTE area-20.0020
100.100.0.105 225.1.2.3 16003008 4052 vn-area-20.0020 HOME area-10.0010
100.100.0.105 225.1.2.3 16153057 4051 vn-area-30.0030 REMOTE area-20.0020
100.100.0.105 225.1.2.4 16003005 4051 vn-area-20.0020 HOME area-10.0010
100.100.0.105 225.1.2.4 16153065 4051 vn-area-30.0030 REMOTE area-20.0020
100.100.0.105 225.1.2.5 16003002 4052 vn-area-20.0020 HOME area-10.0010
100.100.0.105 225.1.2.5 16153073 4051 vn-area-30.0030 REMOTE area-20.0020
100.100.0.105 225.1.3.1 16002999 4051 vn-area-20.0020 HOME area-10.0010
100.100.0.105 225.1.3.1 16153081 4051 vn-area-30.0030 REMOTE area-20.0020
100.100.0.105 225.1.3.2 16002997 4051 vn-area-20.0020 HOME area-10.0010
100.100.0.105 225.1.3.2 16153087 4051 vn-area-30.0030 REMOTE area-20.0020
--More-- (q = quit)
Switch:1# show isis spbm ip-multicast-route vsn-isid 5010
SPBM IP-MULTICAST ROUTE INFO - VLAN ID : 501, VSN-ISID : 5010
192.0.2.1 233.252.0.1 16300001 10 el2 HOME area-10.0010
192.0.2.1 233.252.0.2 16300002 20 el2 HOME area-10.0010
192.0.2.1 233.252.0.3 16300003 10 el2 HOME area-10.0010
192.0.2.1 233.252.0.4 16300004 20 el2 HOME area-10.0010
192.0.2.1 233.252.0.5 16300005 10 el2 HOME area-10.0010
192.0.2.1 233.252.0.6 16300006 20 el2 HOME area-10.0010
192.0.2.1 233.252.0.7 16300007 10 el2 HOME area-10.0010
192.0.2.1 233.252.0.8 16300008 20 el2 HOME area-10.0010
192.0.2.1 233.252.0.9 16300009 10 el2 HOME area-10.0010
192.0.2.1 233.252.0.10 16300010 20 el2 HOME area-10.0010
Switch:1# show isis spb-mcast-summary
SPB Multicast - Summary
SCOPE SOURCE GROUP DATA LSP HOST AREA AREA NAME
I-SID ADDRESS ADDRESS I-SID BVID FRAG NAME
5010 192.0.2.1 233.252.0.1 16300001 10 0x0 el2 HOME area-10.0010
5010 192.0.2.1 233.252.0.3 16300003 10 0x0 el2 HOME area-10.0010
5010 192.0.2.1 233.252.0.5 16300005 10 0x0 el2 HOME area-10.0010
5010 192.0.2.1 233.252.0.7 16300007 10 0x0 el2 HOME area-10.0010
5010 192.0.2.1 233.252.0.9 16300009 10 0x0 el2 HOME area-10.0010
5010 192.0.2.1 233.252.0.2 16300002 20 0x0 el2 HOME area-10.0010
5010 192.0.2.1 233.252.0.4 16300004 20 0x0 el2 HOME area-10.0010
5010 192.0.2.1 233.252.0.6 16300006 20 0x0 el2 HOME area-10.0010
5010 192.0.2.1 233.252.0.8 16300008 20 0x0 el2 HOME area-10.0010
5010 192.0.2.1 233.252.0.10 16300010 20 0x0 el2 HOME area-10.0010
