Configure the SNMP table of filter profiles to determine whether particular management targets receive particular notifications.
- Select Notify Table.
- Select the Notify Filter Table tab.
- Select Insert.
- In NotifyFilterProfileName, type a name for the notify filter profile.
- In Subtree, type the subtree location information in x.x.x.x.x.x.x.x.x.x. format.
- In Mask, type the mask location in hex string format.
- From Type, select included or excluded.
- Select Insert.
Notify Filter Table Field Descriptions
Use the data in the following table to use the Notify Filter Table tab.
Name |
Description |
NotifyFilterProfileName |
Specifies the name of the filter profile used to generate notifications. |
Subtree |
Specifies the MIB subtree that, if you combine it with the mask, defines a family of subtrees, which are included in or excluded from the filter profile. For more information, see RFC 2573. |
Mask |
Specifies the bit mask (in hexadecimal format) that, in combination with the subtree, defines a family of subtrees, which are included in or excluded from the filter profile. |
Type |
Indicates whether the family of filter subtrees are included in or excluded from a filter. The default is included. |
