The notify filter profile exists.
Configure the profile table to associate a notification filter profile with a particular set of target parameters.
- Select Notify Table.
- Select the Notify Filter Profile Table tab.
- Select Insert.
- In TargetParamsName, type a name for the target parameters.
- In NotifyFilterProfileName, type a name for the notify filter profile.
- Select Insert.
Notify Filter Profile Table Field Descriptions
Use the data in the following table to use the Notify Filter Profile Table tab.
Name |
Description |
TargetParamsName |
Specifies the unique identifier associated with this entry. |
NotifyFilterProfileName |
Specifies the name of the filter profile to use to generate notifications. |
