Perform the following procedure to configure coordinate based location information of local LLDP-MED on specific ports.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure coordinate based location:
    lldp location-identification coordinate (altitude WORD<1-13> {floors | meters} datum {NAD83/MLLW | NAD83/NAVD88 | WGS84} latitude WORD<1-14> {NORTH | SOUTH} longitude WORD<1-14> {EAST | WEST})
Configuring coordinate based location on port 1/2:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabitEthernet 1/2
Switch:1(config-if)#lldp location-identification coordinate-base altitude 3 floors
The following table defines parameters for the lldp location-identification coordinate command.
Variable
Value
altitude WORD<1–13>
Specifies the value for altitude. The units of measurement are:
  • floors
  • meters
datum
Specifies the reference datum. The formats are:
  • NAD83/MLLW
  • NAD83/NAVD88
  • WGS84
latitude WORD<1-14>
Specifies the latitude in degrees, and its relation to the equator from North or South.
Specifies the longitude in degrees, and its relation to the prime meridian from East or West.
