Use the following procedure to display the IP unicast Forwarding Information Base (FIB). The tab shows IP routes from remote Backbone Edge Bridges (BEBs)
The IP Unicast FIB tab displays all of the IS-IS routes in the IS-IS LSDB. The Preference column in the IP Unicast FIB tab displays the IP route preference.
- Select SPBM.
- Select the IP Unicast FIB tab.
IP Unicast FIB Field Descriptions
Use the data in the following table to use the IP Unicast FIB tab.
Name |
Description |
VrfId |
Specifies the VRF ID of the IP unicast FIB entry, 0 indicates NRE. |
DestinationIpAddrType |
Specifies the address type of the destination IP address. |
DestinationIpAddr |
Specifies the destination IP Address of the IP unicast FIB entry. |
DestinationMask |
Specifies the destination IP mask of the IP unicast FIB entry |
NextHopBmac |
Specifies the nexthop BMAC of the IP unicast FIB entry. |
DestId |
Specifies the destination I-SID of the IP unicast FIB entry. |
Vlan |
Specifies the VLAN of the IP unicast FIB entry. |
Isid |
Specifies the I-SID of the IP unicast FIB entry. |
NextHopName |
Specifies the nexthop hostname of the IP unicast FIB entry. |
OutgoingPort |
Specifies the outgoing port of the IP unicast FIB entry. |
PrefixCost |
Specifies the prefix cost of the IP unicast FIB entry. |
SpbmCost |
Specifies the BMAC cost of the IP unicast FIB entry. |
Preference |
Specifies the IP Route preference of the IP unicast FIB entry |
MetricType |
Specifies the IP Metric Type of the IP unicast FIB entry. |
