Use the following procedure to configure SPBM on an interface.
- Select IS-IS.
- Select the Interfaces tab.
- Select an interface.
- Select SPBM.
- Select the Interfaces SPBM tab.
- Select Insert.
- Enter the SPBM ID.
- Select Insert.
Interfaces SPBM Field Descriptions
Use the data in the following table to use the Interfaces SPBM tab.
Name |
Description |
Index |
Specifies an Index value for the SPBM interface. |
SpbmId |
Specifies the SPBM ID. |
State |
Specifies whether the SPBM interface is enabled or disabled. |
Type |
Configures the SPBM instance interface-type on the IS-IS interface located on the specified port or MLT: ptpt or bcast. Only the point-to-point (ptpt) interface type is supported. |
L1Metric |
Configures the IS-IS Interface level 1 metric on the specified port or MLT. The default value for L1 metric is 10 for any link, despite the port speed. Configure to auto to use the inverse of the port speed as the metric. |
| Origin |
Specifies the source of the SPBM instance configuration, either manually configured through CLI or EDM, or dynamically configured through Auto-sense. |
