Use the following procedure to verify the proper global SPBM configuration.
Switch# show isis spbm
ISIS SPBM Info
SPBM B-VID PRIMARY NICK LSDB IP IPV6 MULTICAST SPB-PIM-GW STP-MULTI
INSTANCE VLAN NAME TRAP HOMING
1 4051-4052 4051 disable disable disable enable disable enable
ISIS SPBM SMLT Info
SPBM SMLT-SPLIT-BEB SMLT-VIRTUAL-BMAC SMLT-PEER-SYSTEM-ID
INSTANCE
1 primary 00:00:00:00:00:00
Total Num of SPBM instances: 1
Switch# show vlan basic
Vlan Basic
VLAN INST
ID NAME TYPE ID PROTOCOLID SUBNETADDR SUBNETMASK VRFID ORIGIN
1 Default byPort 0 none N/A N/A 0 CONFIG
10 VLAN-10 spbm-bvlan 62 none N/A N/A 0 CONFIG
20 VLAN-20 spbm-bvlan 62 none N/A N/A 0 CONFIG
100 VLAN-100 byPort 0 none N/A N/A 0 CONFIG
All 5 out of 5 Total Num of Vlans displayed
