  • A private VLAN must be created. For more information about creating private VLANs, see Create a Private VLAN.
Assign one I-SID for each private VLAN.
    enable
    configure terminal
  2. Assign the I-SID to the primary and secondary VLAN.
    vlan i—sid <1-4059> <0-16777215> [force]
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#vlan i-sid 5 75
Switch:1(config)#show vlan private-vlan
        PRIVATE VLAN
Primary              Primary              Secondary            Secondary
VLAN                 ISID                 VLAN                 ISID
5                    75                    6                    75
The following table defines parameters for the vlan i-sid command.
Variable
Value
<1-4059>
Specifies the VLAN ID.
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
<0-16777215>
Specifies the service instance identifier (I-SID). You cannot use I-SID 0x00ffffff. The system reserves this I-SID to advertise the virtual BMAC in an SMLT dual-homing environment.
This value is the same for the primary and secondary VLANs.
force
Specifies the software must replace the existing VLAN-to-I-SID mapping, if one exists.
