Perform the following procedure to view Node Alias protocol information.
Detailed information displays for IPv4, IPv6, BGP, VRRP, and broadcast UDP protocols only.
- Select Node Alias.
- Select the Protocol Info tab.
Protocol Info Field Descriptions
Use the data in the following table to use the Protocol Info tab.
| Name | Description |
| SourceMacAddress | Displays the source MAC address. |
| Isid | Displays the I-SID. |
| Vlan | Displays the VLAN. |
| InterfaceIndex | Displays the receiving port or MLT interface. |
| Type | Displays the protocol type. |
| Value | Displays additional details regarding the used protocol, such as:
| Isid Value | Displays the I-SID value of the I-SID-to-VLAN assignment. |
| LastLearnedTimer | Displays the timestamp when the client was last updated on the port. |
