Perform the following procedure to view Node Alias client information.
- Select Node Alias.
- Select the Client Info tab.
- Optional:
                To clear a single client from the database, double-click an entry in the
                        EntryClear column.
                - Select true.
- Select Apply.
Client Info Field Descriptions
Use the data in the following table to use the Client Info tab.
| Name | Description |
| MacAddress | Displays the MAC address of the client. |
| Isid Index | Displays details for the specified I-SID. |
| Vlan Index | Displays details for the specified VLAN ID. |
| Isid Value | Displays the I-SID value of the I-SID-to-VLAN assignment. |
| InterfaceIndex | Displays the receiving interface port or MLT. |
| Capabilities | Displays the protocols the client uses. |
| IsActive | Displays if the client is active. |
| Ipv4Addr | Displays the last IPv4 address used by this client. Note: Option 53 reads the IP address. |
| Ipv6Addr | Displays the last IPv6 address used by this client. |
| FirstLearnedTimer | Displays the timestamp when the client was first detected on the port. |
| LastLearnedTimer | Displays the timestamp when the client was last detected on the port. |
| EntryClear | Clears the client entry from the database. |
| Hostname | Displays the client host name. |
| OSType | Displays the client operating system type. |
| DeviceType | Displays the client device type. |
| OSVersion | Displays the client operating system version. |
