Use port-based shaping to rate-limit all outgoing traffic to a specific rate.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure port-based shaping:
    qos if-shaper [port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] shape-rate WORD<1000-100000000>
The following table defines parameters for the qos if-shaper command.
Variable
Value
Specifies the slot and port number to which to apply shaping. This variable is optional.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
Specifies the shaping rate in Kb/s. If you try to configure a limit that is too high for the port speed, the switch displays the following message:
Error: port slot/port, The QOS Egress shaper rate can not exceed the port capability.
The default is 0, which means shaping is disabled on the port.
