Use this procedure to view the port-based shaper information. The system displays the port, egress rate limit in Kbps, and the rate limit status.
enable
show qos shaper interface gigabitEthernet [{sub-port]][,...][slot/all][all]}]
Switch:1#show qos shaper interface gigabitEthernet 1/1 ================================================================================ Port Egress Rate-Limiting(Shape) ================================================================================ -------------------------------------------------------------------------------- PORT EGRESS RATE-LIMIT(kbps) ENABLED/DISABLED -------------------------------------------------------------------------------- 1/1 0 DISABLED
