Configure Maximum NEAP Clients
Use this procedure to configure the maximum NEAP clients allowed on the port at one time.
Configure the maximum NEAP clients allowed on the port at one time.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/1 Switch:1(config)#eapol multihost non-eap-mac-max 10
The following table defines parameters for the eapol multihost non-eap-mac-max command.
Variable |
Value |
<0–8192> |
Specifies the maximum NEAP clients allowed on the port at one time. The default is 2. |
