Configure Maximum EAP Clients
Use this procedure to configure the maximum EAP clients allowed on the port at one time.
Configure the maximum EAP clients allowed on the port at one time.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/1 Switch:1(config)#eapol multihost eap-mac-max 10
The following table defines parameters for the eapol multihost eap-mac-max command.
Variable |
Value |
<0–32> |
Specifies the maximum EAP clients allowed on the port at one time. The default is 2. |
