During the device bootup, if an older version of a CPLD module is detected, the system displays a log message to upgrade the CPLD module image.
You can also use show sys-info cpld command to check the current version of the CPLD module on the device.
Upgrade the software on the switch to the latest build.
The cpld-install command compares the image version of the modules with the current version on the device:
If the versions are the same, the command exits.
If the current version is an earlier version, you must update the image version of the specific module.
The device automatically restarts after sucessful installation of the specific module.
The following table defines parameters for the cpld-install command.
Variable |
Value |
app |
Updates the APP module. |
boot |
Updates the BOOT module. |
main |
Updates the main CPLD module. |
port |
Updates the Port module. |
WORD<1-99> |
Specifies the image file name. Note: This parameter
is optional. If you do not specify the file name, the command
checks the image file for the image from the running file
system.
