Create an IP VPN instance to advertise IP routes from one VRF to another across a Shortest Path Bridging MAC (SPBM) network.
  • The VRF must exist.
  1. Enter VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    router vrf WORD<1-16>
  2. Create an IP VPN instance on the VRF:
    ipvpn
  3. Assign a service instance identifier (I-SID) to the IP VPN:
    i-sid <0–16777215>
  4. Enable IP VPN on the VRF:
    ipvpn enable
    By default, a new IP VPN instance is disabled.
  5. Display all IP VPNs:
    show ip ipvpn [vrf WORD<1–16>] [vrfids WORD<0–512>]
From Global Configuration mode, log on to Router VRF Configuration mode:
Switch:1(config)# router vrf red
Create the IP VPN instance:
Switch:1(router-vrf)# ipvpn
Enable IP VPN:
Switch:1(router-vrf)# i-sid 100
Enable IP VPN:
Switch:1(router-vrf)#ipvpn enable
                                        IPv4 IPVPN
VRF Name            VRF ID   IPv4 IPVPN   IPv6 IPVPN   I-SID        I-SID Name
red                 1        enabled      disabled     100          ISID-1
1 out of 1 Total active IPv4 L3 VSN displayed, including 0 active IPv6 L3 VSN.
Variable definitions
Use the data in the following table to use the show ip ipvpn command.
Variable
Value
vrf WORD<1–16>
Specifies the VRF name.
vrfids WORD<0–512>
Specifies the VRF ID.
Use the data in the following table to use the i-sid command.
Variable
Value
i-sid <0–16777215>
Assigns an I-SID to the VRF to configure. Use the no or default option to remove the I-SID to VRF allocation for this VRF.
