Perform this procedure to view PoE Power Sourcing Entity (PSE) information for local LLDP-MED on specific ports.
- Select Port MED.
- Select the Local PoE PSE tab.
Local PoE PSE Field Descriptions
Use the data in the following table to use the Local PoE PSE tab.
Name |
Description |
PortNum |
Specifies the port. |
PSEPortPowerAvailable |
Specifies the value of the power available (in units of 0.1 watts) from the PSE through the specific port. |
PSEPortPDPriority |
Specifies the Power Device (PD) power priority for the PSE port (see RFC 3621):
