Perform this procedure to view capabilities information for remote LLDP-MED on specific ports based on the information advertised by the remote device and received on each port in the capabilities TLV.
- Select Port MED.
- Select the Neighbor Capabilities tab.
Neighbor Capabilities Field Descriptions
Use the data in the following table to use the Neighbor Capabilities tab.
Name |
Description |
TimeMark |
Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
LocalPortNum |
Specifies the port on which the remote LLDP-MED information is received. |
Index |
Specifies the connection instance unique to the remote LLDP-MED. |
CapSupported |
Specifies the LLDP-MED capabilities supported on the remote system. |
CapCurrent |
Specifies the LLDP-MED capabilities that are enabled on the remote system. |
DeviceClass |
Specifies the remote LLDP-MED device class. |
