If you enter a virtual router ID or an IP address when showing VRRP interface information, the system displays the information only for that virtual router ID or for that interface.
Switch:1#show ip vrrp interface
Vlan Vrrp
VLAN VRF VRRP IP VIRTUAL VERSION ORIGIN
ID NAME ID ADDRESS MAC ADDRESS
10 GlobalRouter 37 10.10.0.254 00:00:5e:00:01:25 2 dvr
400 GlobalRouter 1 40.40.0.254 00:00:5e:00:01:01 2 config
All 2 out of 2 Total Num of Vlan Vrrp displayed
Port Vrrp
PORT VRF VRRP IP VIRTUAL VERSION
NUM NAME ID ADDRESS MAC ADDRESS
Switch:1#show ip vrrp interface verbose
Vlan Vrrp Extended
VLAN VRRP VRF MASTER ADVERTISE CRITICAL VERSION HOSTNAME ORIGIN
ID ID NAME STATE CONTROL PRIORITY IPADDR INTERVAL IPADDR
10 37 Global~ backup enable 100 0.0.0.0 1 0.0.0.0 2 dvr
400 1 Global~ master enable 100 40.40.0.12 1 0.0.0.0 2 config
All 2 out of 2 Total Num of Vlan Vrrp Extended Entries displayed
VLAN VRRP VRF HOLDDWN ACTION CRITICAL BACKUP BACKUP FAST ADV FAST ADV VERSION
ID ID NAME TIME IP MASTER MASTER INTERVAL ENABLE
ENABLE STATE
10 37 GlobalRouter 60 none disable disable down 200 disable 2
400 1 GlobalRouter 0 none disable disable down 200 disable 2
All 2 out of 2 Vlan Vrrp Extended Entries displayed
VLAN VRRP VRF MASTER ADV PREEMPT PSEUDO-HEADER VERSION
ID ID NAME INTERVAL(ms) MODE CHECKSUM
10 37 GlobalRouter N\A enabled disabled 2
400 1 GlobalRouter N\A enabled disabled 2
Port Vrrp Extended
PORT VRRP VRF MASTER ADVERTISE CRITICAL VERSION
NUM ID NAME STATE CONTROL PRIORITY IPADDR INTERVAL IPADDR
PORT VRRP VRF HOLDDWN ACTION CRITICAL BACKUP BACKUP FAST ADV FAST ADV VERSION
NUM ID NAME TIME IP MASTER MASTER INTERVAL ENABLE
ENABLE STATE
PORT VRRP VRF MASTER ADV PREEMPT PSEUDO-HEADER VERSION
NUM ID NAME INTERVAL(ms) MODE CHECKSUM
Variable definitions
Use the data in the following table to use the show ip vrrp interface command.
Variable |
Value |
gigabitethernet {slot/port[-slot/port][,...]} |
Specifies to show the VRRP information of which interface. |
verbose |
Specifies to show all available information about the VRRP interfaces. |
vlan |
Specifies the VLAN that contains the VRRP. |
vrf WORD<1-16> |
Specifies the name of the VRF. |
vrid <1-255> |
Specifies a unique integer value that represents the virtual router ID in the range 1–255. The virtual router acts as the default router for one or more assigned addresses. |
vrfids WORD<0-512> |
Specifies the ID of the VRF and is an integer in the range of 0–512. |
version<2–3> |
Specifies the VRRP version (2 or 3) configured. |
