View IP VRRPv3 Statistics
Use the following procedure to view IP VRRPv3 statistics to monitor network performance.
View IP VRRPv3 statistics:
Switch:1#show ip vrrp statistics
VRRP Global Stats - GlobalRouter
CHK_SUM_ERR VERSION_ERR VRID_ERR VRRP_VERSION
0 0 0 2
0 0 0 3
VRRP Interface Stats - GlobalRouter
VRRP ID P/V BECOME_MASTER ADVERITSE_RCV VERSION
3 3 1 0 2
2 1/1 1 0 3
VRRP ID P/V ADVERTISE_INT_ERR TTL_ERR PRIO_0_RCV VERSION
3 3 0 0 0 2
2 1/1 0 0 0 3
VRRP ID P/V PRIO_0_SENT INVALID_TYPE_ERR ADDRESS_LIST_ERR UNKNOWN_AUTHTYPE VERSION
3 3 0 0 0 0 2
2 1/1 0 0 0 0 3
VRRP ID P/V AUTHTYPE_ERR PACKLEN_ERR VERSION
3 3 0 0 2
2 1/1 0 0 3
Use the data in the following table to use the ip vrrp version command.
Variable |
Value |
version <2–3> |
Specifies the version of VRRP (2 or 3) to be configured on the specified interface. |
vrf WORD<1–16> |
Specifies the name of the VRF. |
vrfids WORD<0–512> |
Specifies the ID of the VRF. |
