Use this procedure to configure the Connectivity Fault Management (CFM) Maintenance Association (MA). An MA represents a logical grouping of monitored entities within its domain. It can therefore represent a set of Maintenance Association Endpoints (MEPs), each configured with the same Maintenance Association ID (MAID) and MD Level, established to verify the integrity of a single service instance.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# cfm maintenance-association md1 ma1 index 98
Switch:1(config)# show cfm maintenance-association
Maintenance Association Status
Domain Name Assn Name Domain Idx Assn Idx
md1 ma1 1 98
Total number of Maintenance Association entries: 1.
Maintenance Association config
md1 ma1
Total number of MA entries: 1.
The following table defines parameters for the cfm maintenance-association command.
Variable |
Value |
WORD<0–22> WORD<0–22> |
Creates the CFM MA. The first parameter, specifies the MD name. The second parameter, specifies the MA short name. |
index <1–2147483647> |
Specifies a maintenance association entry index. |
