Secure Control Messages
Configure Message Digest (MD) 5 authentication to secure control messages on the TCP connection between MSDP peers.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip msdp md5–authentication 21.0.0.2 enable Switch:1(config)#ip msdp password peer 21.0.0.2 helloworld
Variable definitions
The following table defines parameters for the ip msdp command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP peer IP address. |
WORD<1-80> |
Specifies the MD5 authentication password. |
