Configure a Peer Description
Configure a peer description to add descriptive text to an MSDP peer for easy identification of a peer.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip msdp peer 21.0.0.2 primary
Variable definitions
The following table defines parameters for the ip msdp description command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP peer IP address. |
WORD<1-255> |
Specifies a descriptive text to a MSDP peer in the range of 1-255 characters. To include spaces in the peer description, enclose the text string in quotation marks. |
