Use this procedure to configure the maximum EAP and NEAP MAC clients supported on a port.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface GigabitEthernet 1/16 Switch:1(config-if)# eapol multihost mac-max <1-8192>
The following table defines parameters for the eapol multihost mac-max command.
Variable |
Value |
mac-max <1-8192> |
Specifies the maximum number of EAP and NEAP MAC addresses allowed on the port. The maximum limit is 8192 MAC addresses. |
