Use this task to configure or view IPv6 address information for a Segmented Management Instance.
Ensure the IP address you plan to assign is not in use by an existing VLAN or CLIP IP subnet configured on the switch.
- Select Mgmt Instance.
- Select Mgmt.
- Select the Ipv6Address tab.
- Select Insert.
- Select the Segmented Management Instance interface type.
- Type the address information.
- Select Insert.
Ipv6Address Field Descriptions
Use the data in the following table to use the Ipv6Address tab.
Name |
Description |
InstanceId |
Specifies the interface instance. |
Address |
Specifies the IPv6 address for the interface instance. Ensure that the management CLIP IP address does not fall into the range of a configured VLAN IP address range as this is not allowed. |
PrefixLength |
Specifies the prefix length for the IPv6 address. |
AddrOrigin |
Shows the IPv6 address origin. |
IntfName |
Shows the interface name. |
DadStatus |
Shows the IPv6 DAD status of the address. |
