Perform this procedure to filter on specific Ethernet destination addresses.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select Eth.
- Select the Destination Address tab.
- Select Insert.
- Specify the ACE Ethernet operation.
- In the List dialog box, specify the Ethernet source address.
- Select Insert.
Destination Address Field Descriptions
Use the data in the following table to use the Destination Address tab.
Variable |
Value |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits. |
List |
Specifies the MAC address to match. |
OperMask |
Specifies the MAC address mask value in hexadecimal format if the Oper variable is mask. The value of this variable is empty or 000000000000 if Oper is eq. |
