Perform this procedure to filter for specific LAN traffic packets.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select Eth.
- Select the Ethernet Type tab.
- Select Insert.
- Specify the operation type.
- In the TypeList box, type the Ethernet types.
- Select Insert.
Ethernet Type Field Descriptions
Use the data in the following table to use the Ethernet Type tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
TypeOper |
The eq parameter specifies an operator for a field match condition: equal to. |
TypeList |
Specifies the Ethernet type. Entries include: 0 to 0xffff or ip, arp, ipx802.3, ipx802.2, ipxSnap, ipxEthernet2, appleTalk, appleTalk-ARP, sna802.2, snaEthernet2, netBios, xns, vines, ipv6, rarp, PPPoE-discovery, and PPPoE-session. Note:
Ethernet ACE filter configured with Ethernet Type ipx802.3 does not match the packet with format destination MAC address, source MAC address, length, 0xFFFF, payload and FCS. Ethernet ACE filter configured with Ethernet Type ipx802.2 does not match the packet with format destination MAC address, source MAC address, length, 0xE0E0, payload and FCS. |
