View Primary IP Addresses
Use this procedure to view primary IP addresses (and their associated router interfaces) from one central location.
You can also use this tab to configure a name or MAC offset for the interface.
- Select IP.
- Select the Primary Addresses tab.
Primary Addresses Field Descriptions
Use the data in the following table to use the Primary Addresses tab.
Name |
Description |
Interface |
Specifies the router interface. |
Ip Address |
Specifies the IP address of the router interface. |
Net Mask |
Specifies the subnet mask of the router interface. |
BcastAddrFormat |
Specifies the IP broadcast address format used on this interface; that is, whether 0 (zero) or one is used for the broadcast address. The switch uses 1. |
ReasmMaxSize |
Specifies the size of the largest IP packet that this interface can reassemble from incoming fragmented IP packets. |
VlanId |
Identifies the VLAN associated with this entry. This value corresponds to the lower 12 bits in the IEEE 802.1Q VLAN tag. |
BrouterPort |
Indicates whether this is a brouter port (as opposed to a routable VLAN). |
MacOffset |
Specifies a number by which to offset the MAC address of the VLAN from the chassis MAC address. This ensures that each IP address has a different MAC address. |
