View all IP Addresses
Use this procedure to view primary or secondary IP addresses on all interface types from one EDM tab.
You can create a Secondary IP Interface only on a VLAN interface.
- Select IP.
- Select the All Addresses tab.
All Addresses Field Descriptions
Use the data in the following table to use the All Addresses tab.
| Name | Description |
Interface |
Identifies the IP interface. |
Type |
Displays the address type, either primary or secondary. |
Ip Address |
Displays the IP address. |
Net Mask |
Displays the subnet mask for the address. |
VlanId |
Displays the VLAN ID, if applicable. |
VrfId |
Displays the associated VRF ID, if applicable. |
