For IPv4, enter: show interfaces vlan ip
For IPv6, enter: show ipv6 interface vlan
Verify the IPv4 interface configuration on the VLAN:
Switch:1(config-if)# show interfaces vlan ip
Vlan Ip
VLAN VRF IP NET ADMIN OPER ADVERTISE DIRECTED RPC RPCMODE RMON
ID NAME ADDRESS MASK STATUS STATUS WHEN_DOWN BROADCAST
1050 Globa~ 192.0.2.9 255.255.255.0 enable up disable disable disable exist-only disable
1102 Globa~ 198.51.100.1 255.255.255.0 enable up disable disable disable exist-only disable
1133 iir3 192.0.2.10 255.255.255.0 enable up disable disable disable exist-only disable
1500 spboip 192.0.2.11 255.255.255.0 enable up disable disable disable exist-only disable
1590 spboip 198.51.100.2 255.255.255.0 enable up disable disable disable exist-only disable
4057 Globa~ 192.0.2.12 255.255.255.0 enable up disable disable disable exist-only disable
All 16 out of 16 Total Num of Vlan Ip Entries displayed
VLAN VRF BCASTADDR REASM DVR DVR
ID NAME FORMAT MAXSIZE STATE GW-IPv4
1050 GlobalRouter ones 1500 disable -
1102 GlobalRouter ones 1500 disable -
1133 iir3 ones 1500 disable -
1500 spboip ones 1500 disable -
1590 spboip ones 1500 disable -
4057 GlobalRouter ones 1500 disable -
Verify the IPv6 configuration on the port:
Switch:1(config-if)# show ipv6 interface vlan
Vlan Ipv6 Interface
IFINDX VLAN PHYSICAL ADMIN OPER TYPE MTU HOP REACHABLE RETRANSMIT MCAST IPSEC RPC RPCMODE
INDX ADDRESS STATE STATE LMT TIME TIME STATUS
3170 1122 2c:f4:c5:dc:b4:89 enable up ETHER 1500 64 30000 1000 disable disable disable existonly
3174 1126 2c:f4:c5:dc:b4:8b enable up ETHER 1500 64 30000 1000 disable disable disable existonly
3185 1137 2c:f4:c5:dc:b4:90 enable up ETHER 1500 64 30000 1000 disable disable disable existonly
Vlan Ipv6 Address
IPV6 ADDRESS VLAN-ID TYPE ORIGIN STATUS
2001:db8:0:0:0:0:0:1 V-1122 UNICAST MANUAL PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b489 V-1122 UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1 V-1126 UNICAST MANUAL PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b48b V-1126 UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1 V-1137 UNICAST MANUAL PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b490 V-1137 UNICAST LINKLAYER PREFERRED
3 out of 4 Total Num of Interface Entries displayed.
6 out of 7 Total Num of Address Entries displayed.
