Use this procedure to verify the configuration of all IP addresses, including Secondary IP Interfaces on VLANs. You cannot create Secondary IP Interfaces on brouter ports.
  1. To enter User EXEC mode, log on to the switch.
  2. Display all configured IP addresses:
    show ip address
  3. Display all primary IP addresses:
    show ip address primary
  4. Display all secondary IP addresses:
    show ip address secondary
  5. Display IP addresses associated with a VLAN:
    show ip address vlan [vlan-id[-vlan-id][,...]}<1-4059>]
  6. Display IP addresses associated with a VRF name:
    show ip address vrf WORD<1-16>
  7. Display IP addresses associated with a VRF ID:
    show ip address vrfids WORD<0-512>
