View fan information to monitor the alarm status of the cooling ports in the chassis.
For platforms that support both back-to-front and front-to-back airflow, the airflow direction must be the same for both the power supply fans and the chassis fan.
  1. On the Device Physical View, select the Device.
  2. In the navigation pane, expand Configuration > Edit.
  3. Select Chassis.
  4. Select the Fan Info tab.
Fan Info Field Descriptions
Use the data in the following tables to use the Fan Info tab.
Name
Description
Description
Specifies a description of the fan location.
OperStatus
Specifies the operation status of the fan.
OperSpeed
Specifies the actual fan speed.
OperSpeedRPM
Specifies the current operational speed of the fan in RPM.
