Configure a forced message control pattern to enforce configured message control actions.
- In the navigation pane, expand Configuration > Edit > Chassis.
- Select the Force Msg Patterns tab.
- Select Insert.
- In PatternId, type a pattern ID number.
- In Pattern, type a message control pattern.
- Select Insert.
Force Msg Patterns Field Descriptions
Use the data in the following table to use the Force Msg Patterns tab.
Name |
Description |
PatternId |
Specifies a pattern identification number in the range 1–32. |
Pattern |
Specifies a forced message control pattern of 4 characters. The software and the hardware log messages that use the first four bytes matching one of the patterns in the force-msg table undergo the configured message control action. You can specify up to 32 different patterns in the force-msg table, including a wildcard pattern (****). If you specify the wildcard pattern, all messages undergo message control. |
