Perform this task to configure the time, in seconds, for Auto-sense to wait for a Link Layer Discovery Protocol (LLDP) neighbor to be detected in the Auto-sense wait state before transitioning to the Auto-sense onboarding state.
The per-port wait-interval configuration takes precedence over the globally configured Auto-sense wait-interval. If you change the port configuration and the port is already in the wait state, the wait-interval adjusts automatically.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure the wait interval on a port:
    auto-sense wait-interval <10-120>
  3. Verify the Auto-sense wait interval information:
    show interfaces gigabitethernet auto-sense {sub-port]][,...][slot/all][all]}
Configure the Auto-sense wait interval on port 1/1 to 20 seconds:
Switch:1>enable
Switch:1#configure terminal
Switch:1#interface GigabitEthernet 1/1
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#auto-sense wait-interval 20
Verify the Auto-sense wait-interval information for a range of ports:
Switch:1>enable
Switch:1#show interfaces gigabitethernet auto-sense 1/1-1/5
                                Port Auto-sense
PORT     AUTO-SENSE   AUTO-SENSE         AUTO-SENSE       AUTO-SENSE
NUM      STATUS       STATE              PORT-DATA-ISID   PORT-WAIT-INTERVAL
1/1      Enable       FA-PROXY-RING      --               20
1/2      Enable       SD-WAN              --              10
1/3      Enable       DOWN               --               10
1/4      Enable       DOWN               --               10
1/5      Disable      OFF                --               10
The following table defines parameters for the auto-sense wait-interval command.
Variable
Value
<10-120>
Specifies the Auto-sense wait interval, in seconds, for a specific port. The port-specific configuration takes precedence over the global wait-interval configuration. The default value is 35.
