Perform this task to configure the time, in seconds, for Auto-sense to wait for a Link Layer Discovery Protocol (LLDP) neighbor to be detected in the Auto-sense wait state before transitioning to the Auto-sense onboarding state.
Configure the Auto-sense wait interval as 50 seconds:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense wait-interval 50
Verify the Auto-sense wait-interval information:
Switch:1>show auto-sense wait-interval ============================================================================ AUTO-SENSE GLOBAL Config ============================================================================ WAIT INTERVAL ---------------------------------------------------------------------------- 50 ---------------------------------------------------------------------------- ---------------------------------------------------------------------------- 0 out of 0 Total Num of AUTO-SENSE entries displayed ----------------------------------------------------------------------------
The following table defines parameters for the auto-sense wait-interval command.
Variable |
Value |
<10-120> |
Specifies the global Auto-sense wait interval, in seconds. The global configuration applies to all Auto-sense ports unless you configure a port specific wait-interval. The default value is 35. |
