Perform this procedure to configure Multi-area SPB Layer 3 redistribution in the home area.
- Select MultiArea.
- Select the L3 Redist Home tab.
- Select Insert.
- In VrfId, type the Virtual Router Forwarding ID.
- In Type, select the Layer 3 redistribution type.
- Optional: In RoutePolicy, type the name of the redistribution policy.
- Optional: Select DeleteTags to disable the transmission of route tags in Multi-area SPB.
- Select Enable.
- In Apply, select apply.
- Select Insert.
L3 Redist Home Field Descriptions
Use the data in the following table to use the L3 Redist Home tab.
| Name | Description |
VrfId |
Specifies the Virtual Router Forwarding ID. |
Type |
Specifies the layer 3 redistribution type. The options are:
RoutePolicy |
Associates a route policy to a specific layer 3 redistribution entry in the home area. |
Enable |
Enables layer 3 redistribution in the home area. The default value is disabled. |
Apply |
Applies the Multi-area SPB layer 3 redistribution filters in the home area. The default value is noAction. |
| DeleteTags | Disables the transmission of route tags in Multi-area SPB. Select this parameter if platforms do not correctly calculate the TLV length in TLV 135. By default, route tags are transported in Multi-area SPB. |
