Perform this procedure to configure Multi-area SPB Layer 3 redistribution in the remote area.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select MultiArea.
  3. Select the L3 Redist Remote tab.
  4. Select Insert.
  5. In VrfId, type the Virtual Router Forwarding ID.
  6. In Type, select the Layer 3 redistribution type.
  7. Optional: In RoutePolicy, type the name of the redistribution policy.
  8. Optional: Select DeleteTags to disable the transmission of route tags in Multi-area SPB.
  9. Select Enable.
  10. In Apply, select apply.
  11. Select Insert.
L3 Redist Remote Field Descriptions
Use the data in the following table to use the L3 Redist Remote tab.
Name Description
VrfId
Specifies the Virtual Router Forwarding ID.
Type
Specifies the layer 3 redistribution type. The options are:
  • ip-ucast - IPv4 unicast
  • ip-mcast - IPv4 multicast
  • ipv6-ucast - IPv6 unicast
RoutePolicy
Associates a route policy to a specific layer 3 redistribution entry in the remote area.
Enable
Enables layer 3 redistribution in the remote area. The default value is disabled.
Apply
Applies the Multi-area SPB layer 3 redistribution filters in the remote area. The default value is noAction.
DeleteTags Disables the transmission of route tags in Multi-area SPB. Select this parameter if platforms do not correctly calculate the TLV length in TLV 135. By default, route tags are transported in Multi-area SPB.
