Create an IPv6 CLIP Interface
Perform this procedure to create an IPv6 CLIP interface and associate it with a specific VRF.
Switch:1#show ipv6 interface loopback ======================================================================================================= Loopback Ipv6 Interfaces ======================================================================================================= IF VRF Descr VLAN PHYSICAL ADMIN OPER TYPE MTU HOP REACHABLE RETRANSMIT IPSEC INDX NAME ADDRESS STATE STATE LMT TIME TIME STATE -------------------------------------------------------------------------------------------------------- 1348 GlobalRouter CLIPv6-5 --00:00:00:00:00:05 enable up ETHER 1500 64 30000 1000 disable ======================================================================================================== Loopback IPv6 Addresses ======================================================================================================== IPV6 ADDRESS/PREFIX LENGTH LOOPBACK-ID TYPE ORIGIN STATUS NAME -------------------------------------------------------------------------------------------------------- 2001:db8:0:0:0:0:0:ffff/32 C-5 UNICAST MANUAL PREFERRED INF INF EXTREMESERVER_2 Legend: NA - Information not available 1 out of 1 Total Num of Interface Entries displayed. 1 out of 1 Total Num of Address Entries displayed.
Use the data in the following table to use the ipv6 commands.
Variable |
Value |
WORD<1–256> |
Specifies the CLIP interface ID. |
WORD<0–255> |
Specifies the IPv6 address. |
vrf WORD<1–16> |
Specifies the VRF name. |
WORD<0–64> |
Specifies the I-SID name associated with the IPv6 address. |
