View routes information to view the current configuration.
Not all parameters are available in non-default VRFs.
IPv6 host routes created for the IPv6 local interfaces do not display in the routing table.
  1. To enter User EXEC mode, log on to the switch.
  2. Show route information for alternative routes:
    show ipv6 route alternative [vrf WORD<1–16> | vrfids WORD<1–256>]
  3. Show the number of OSPF, RIP, static, and local routes:
    show ipv6 route count-summary [vrf WORD<1–16> | vrfids WORD<1–256>]
  4. Show route information for a destination:
    show ipv6 route dest WORD<0–46> [vrf WORD<1–16> | vrfids WORD<1–256>]
  5. Show route information for a port:
    show ipv6 route gigabitethernet {slot/port[sub-port]}
  6. Show route information for a next-hop address:
    show ipv6 route next-hop WORD<0–46> [vrf WORD<1–16> | vrfids WORD<1–256>]
  7. Show route information for an SPBM IPv6 route:
    show ipv6 route spbm-nh-as-mac
  8. Show route information for a static route:
    show ipv6 route static [vrf WORD<1–16> | vrfids WORD<1–256>]
  9. Show route information for a tunnel:
    show ipv6 route tunnel <1–2000>
  10. Show route information for a VLAN:
    show ipv6 route vlan <1-4059>
Switch:1(config-if)#show ipv6 route
                                     IPv6 Routing Table Information - GlobalRouter
Destination Address/PrefixLen            NEXT HOP            NH VRF/ISID       VID/BID/TID  PROTO   COST  AGE   TYPE PREF
22:0:0:0:0:0:0:0/64                      42-VSP-8404             -               V-22        LOCAL   1     0     B    0
123:0:0:0:0:0:0:0/64                     39-4900-24XE            -               C-1         LOCAL   1     0     B    0
2 out of 2 Total Num of Route Entries displayed.
TYPE Legend:
A=Alternative Route, B=Best Route, E=Ecmp Route
Switch:1#show ipv6 route count-summary
                         IPv6 Route Summary - GlobalRouter
  VRF NAME      TOTAL     OSPF      RIP      BGP   STATIC    LOCAL     ISIS
  GlobalRouter   13       10       0        3        1        2        7
Switch:1#show ipv6 route static
                              Static Route Information - GlobalRouter
DEST-IP                                  NET IFINDX(VID/BRT/TUN) ENABLE  STATUS           NAME
NEXT-HOP                                 PREFERENCE
22:0:0:0:0:0:0:0                         64  2059  (V-11     ) enable  NotReachable	ExtSer10
66:0:0:0:0:0:0:66                        5
1 out of 1 Total Num of Static Routes displayed.
Global IPv6 Static Routes Admin Status: enable
Switch:1#show ipv6 route spbm-nh-as-mac
2001:cdab:0:0:0:0:0:0/32         42-VSP-8404           -           V-611        LOCAL   1   0     B    0
2002:cdab:0:0:0:0:0:0/32         VSP-8404              -           V-10         ISIS    1   0     B    0
Use the data in the following table to use the show ipv6 route command.
Variable
Value
count-summary
Shows the total number of OSPF, static, and local routes.
dest WORD<0–46>
Specifies the IPv6 destination network address. The prefix value must match the prefix length.
next-hop WORD<0–46>
Specifies the IPv6 address of the next hop on this route.
spbm-nh-as-mac
Shows the BMAC address as the next hop rather than the host name.
{slot/port[/sub-port]}
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
static
Shows static IPv6 routes.
tunnel <1–2000>
Shows route entries for a specific tunnel ID.
vlan<1-4059>
Shows route entries for a specific VLAN ID.
vrfWORD<1–16>
Shows the VRF name.
vrfidsWORD<1–256>
Shows the VRF ID.
