  1. To enter User EXEC mode, log on to the switch.
  2. View IPSG configuration on a specified interface:
    show ipv6 source-guard interface gigabitEthernet [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
  3. View IPSG configuration on all IPSG enabled interfaces:
    show ipv6 source-guard interface enabled
Switch:1#show ipv6 source-guard interface gigabitEthernet 1/1
Slot/Port  Source Guard  Number of  IPv6  Address
             Mode        address allowed  overflow count
1/1          Enabled           4           0
Switch:1#show ipv6 source-guard interface enabled
1/1          Enabled           4           0
1/2          Enabled           9           0
The following table defines parameters for the show ipv6 source-guard interface gigabitEthernet command.
Variable
Value
enabled
Displays IPSG configuration on all IPSG enabled interfaces.
gigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Displays IPSG configuration on the specified interface.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
