View the IPv6 address bindings that IP Source Guard (IPSG) allows.
  1. To enter User EXEC mode, log on to the switch.
  2. View the allowed IPv6 address bindings:
    show ipv6 source-guard binding [WORD<0-46>] [interface gigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
View the IPv6 address bindings for port 1/3.
Switch:1>show ipv6 source-guard binding interface gigabitEthernet 1/3
Slot/Port    IPv6  Address
1/3          2001::10:10:0:1
1/3          fe80::210:94ff:fe00:550b
View the IPv6 address bindings for a specific IPv6 address.
Switch:1>show ipv6 source-guard binding fe80::210:94ff:fe00:550b
The following table defines parameters for the show ipv6 source-guard binding command.
Variable
Value
WORD<0-46>
Identifies the IPv6 address.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
