Display the IP mroute Routes
Use the following procedure to display multicast routes ingressing on either SPB-PIM Gateway interfaces or SPB multicast interfaces.
  1. In the navigation pane, expand Configuration > IP.
  2. Select Multicast.
  3. Select the Routes tab.
Routes Field Descriptions
Use the data in the following table to use the Routes tab.
Name
Description
Group
Displays the IP multicast group address for this entry that contains multicast routing information.
Source
Displays the network address that, when combined with the corresponding route SourceMask value, identifies the source that contains multicast routing information.
SourceMask
Displays the network mask that, when combined with the corresponding route Source value, identifies the multicast source.
UpstreamNeighbor
Shows the address of the upstream neighbor from which the IP datagrams from these sources are received. The address is 0.0.0.0 if the network is local.
Interface
Displays the interface, slot and portnumber, or VLAN ID where IP datagrams sent by these multicast sourcesto this multicast address are received.
ExpiryTime
Displays the amount of time that remains before this entry ages out. The value 0 indicates that the entry is not subject to aging.
Protocol
Displays the protocol as one of the following:
  • other(1): none of the following
  • local(2): manually configured
  • netmgmt(3): configured by a network management protocol
  • pimSparseMode(8): PIM-SMv2
  • igmpOnly(10)
  • pimSsmMode(11)
  • spb (12)
  • spbpimgw(13)
